M35A2 Clutch Adjusting
REXALL
rogers/ar
I have a 67 Deuce and the truck on has 20,000 miles and runs great. The clutch lets out right at the top. I took the inspection plate off the transmission
housing but I didnt see any way to adjust it. Is it adjusted by the linkages
Floridianson
2,503
Interlachen Fl.
Just make shure by looking up the inspection plate after adj. that the TO bearing is not spinning when the motor is running. Friend just had to replace a new clutch because the Mechanic did not have it right and the TO bearing was riding fulll time. 6 months later it was froze up and did dammage to the fingers.
Warthog
236
OKC, OK
Welcome to SteelSoldiers.
Make sure you download the repair manuals. You can get then for free. A couple of our members have posted them on their websites.
JATONKAM35s HOME ON THE WEB
The adjustment of the clutch is covered in the technical manauls. Very easy to do.
Warthog
REXALL
rogers/ar
Clutch Adjustment help
Thank you for the help.
I recently was pulling my pickup out or the field after getting it stuck and
tore the gear teeth off my pto for mench on my Deuce. I ordered a pto with all new seal, bearings, gaskets, pins and mounting studs for $850. from a military surplus house from Dodge City KS. I hope I dont have that problem again.
