M35A2 compressor mounting/exploded view
1944mb
110
Big Timber, MT
I have an oil leak somewhere originating from my air compressor. I am wondering if the bottom of the compressor allows the oil to drain back to the crankcase-just a speculation on my part. Where is the best spot to find an exploded view
Barrman
1,685
Giddings, Texas
Probably the -34P TM. There is a gasket between the bottom of the compressor and the mount.
I was helping someone recover a truck 700 miles away years ago. It had a bad starter that we didn’t want to use again after the initial start. After about an hour on the road we noticed a little oil on the drivers fender. It never really grew and 12 hours of not turning the truck off later. The leak hadn’t grown and there was still plenty of oil in the engine.
1944mb
110
Big Timber, MT
Did you find out where the oil was coming from>?
cattlerepairman
3,183
NORTH (Canada)
On the new gasket, make sure the round holes at the end , for the oil passages, are open. I have seen gaskets where these were not fully perforated. Your compressor would not enjoy the oil starvation. Just look at the bottom of the compressor foot plate and see the oil holes. There needs to be a corresponding hole in the gasket.
