chris03020
- 0
- 0
- mammoth spring ar.
kinda new here, But i have a 71 am general that ive bobed and finialy got it just about the way i want it and now it wont start. It has the white 6cyl. multy fuel non turbo with 5,000 origonal mi.. I have found some fuel leaks up arround the injectors at the 1/4 in lines and tighten them up when it was still running but then it just quit all together. the in tank pump is working fine so i dont think it was that. The last few times i started it, it seemed to turn over more than usual so im thinking that my leakes caused the fuel do drain back to the tank when it wasent running. I plan to replace all three fuell filters and all the rubber or plastic fuel lines under the hood in hopes it will cure my problem. I would like any input i can get on this matter. O and what about bleading the system after i replace lines and filters
