M35a2 fuel filter help
Rezdeuce
Valley center ca
Hi I was wondering if anyone knows how to take off the m35a2 fuel filters I reaed the TM's and looked around. I took the top bolts off but how do you get the canesters off? There is no nut to anything thanks
DieselBob
13
Arnold Maryland
Yep. The only thing holding them are the top bolts. If they have been on for even a few weeks the gasket will tend to stick the can to the mount.
wreckerman893
Possum Connoisseur
15,620
2,022
If you are very careful not to bugger up the gasket you can replace the filters and reinstall the can....then tighten down the bolt and check for leaks. Getting a new gasket in while hanging upside down can be a real beotch.
If you have to replace the gasket the best thing to do is to remove the filter housing and do it on the bench. Make sure you put the fuel lines back in the correct order.
