M35A2 High Idle Issue
Brenda
Wilmington Ca
Howdy folks,
One of the M35's I got came ready to roll. Even the batteries where brand new. Because of all that I assumed it was in tip top shape. When I went to fire it up the motor ran as if I had the peddel all the way down. I pulled the stop cable out about 3/4 of the way to get the thing down to 1,000 or so RPM. If I let the cable in just a little the **** thing would run away again. It smells like JP4 in the tank so I don't think it is the fuel. However I could be wrong on this. Anyone know why the motor would do this? And how do I get it to idle down?
Warthog
241
OKC, OK
steelandcanvas
87
Southwestern Idaho
Could the smell be spoiled diesel fuel and not JP-4? Take a look at your fuel filters and the bottom of the fuel tank. Spoiled fuel has a rusty brown color and smells like varnish. This spoiled fuel would also contribute to linkages in the IP being sticky. Take a look and come back, tell us what you found.
SMOKEWAGON66
21
California
I dont know about the linkages and throttle levers, but if it has JP4 in it, I think the engine would become a grenade...If all the throttle linkages are fine and set properly and it still runs like that, drain the tank and lines, change the filters etc, and refill with good diesel. I think JP4 could cause an engine to run away and explode so....least thats what I heard.
91W350
57
Salina, Kansas
Does the pedal return or does the pedal stay towards the floor. Could be as simple as a throttle return spring missing. Along the same lines, is the throttle cable all the way in?
gimpyrobb
dumpsterlandingfromorbit!
27,787
778
Cincy Ohio
I agree, they can stick in the closed position, so they don't start, or, as what happened to me, it was stuck WFO. Take the cover off and try to move it by hand. That would be where I started, anyway.
Brenda
Wilmington Ca
Ok the springs are good. Throttle returns to close (firewall). Also internal lever seems to be moving ok as well. It really does smell like kerosene in the tank with a mix of normal gas. Not 100% sure what the USMC put in the thing when I got it. I'm almost positive there is something wrong with the injector pump. Is it normal for them to go bad after sitting for some time?
steelandcanvas
87
Southwestern Idaho
Take the strainer out of the fuel tank and shine a light down in the tank. Let's determine if the fuel is spoiled first. Pull the primary fuel filter and see what's going on in there. There are a lot of things to look at before you throw in the towel and say the IP is the culprit.
Brenda
Wilmington Ca
Forgot about this. **** I'm working to much these days. Problem was the fuel in the tank was not what I normally run. Drained all that and purged system of it. Refilled with #2 from Shell and truck ran smooth as glass. Gave the 5gal I saved to the guys down the road that work on modern trucks to play with. They have no idea what it is either. In a clear glass container the color is sort of milky blue. Out of all the trucks I have this is the only one that had this stuff in the tank.
1,191
Found on the Intrawebs
The desire for a less flammable, less hazardous fuel led the U.S. Air Force to phase out JP-4 in favor of JP-8; the transition was completed by the fall of 1996.
[h=2][/h]
