mitchsc0tt0
- 29
- 18
- Unionville CT
Hey all,
Recently had my air horn solenoid die. Checked all. Wires and verified ground was closing correctly with horn button and hot 24v at other wire. Problem is as soon as I plug in the hot wire it goes on even if I don't plug in the horn button wire from the column. I played around with it and it seems to be grounding to the brass fittings it this normal or a bad unit?
Thanks,
Mitch
Sent from my SAMSUNG-SM-G930A using Tapatalk
Thanks,
Mitch
