m35a2 injection pump concern
Aknoll007
While traveling from detroit to st. louis last weekend the deuce died on me. Problem starting when the #1 injection line cracked and broke I drove another 60 or so miles on 5 cylinders and a leaking from the cracked line. The injection pump then gave.
I am wondering if the cracked line may have damaged the pump and if so what? I verified fuel flow to the pump and removed several injection lines and there was no squirting of fuel. The injection line cracked right at the pump itself. Does anyone have a spare pump to sell? would also like info on pump install and rebuilding. I have the pump out would love some advice. Thanks Alex
WillWagner
2,611
Monrovia, Ca.
Mine wouldn't start, turned out to be the shut off mechanizim in the pump. It was stuck. Take the rectangle shaped cover with 2 screws that the shut down cable goes to on the outboard side of the pump off and push the lever in there all the wav back.. or front, I forget, and see if it will light. I have an xtra fuel line if you need it. Idaho Motor Pool also has some.
