M35A2 Knuckle Boot Grease Type
Desperado08
Vallecitos/NM
I need to know what type of grease you can use in your knuckle boot for an m35a2 2.5 ton. Thanks and is there an alternate that I can buy from an auto parts store or is it special order only.
Wildchild467
56
Milford / Michigan
i think its just regular chassis and bearing lube.... Napa will have the stuff. going to need a lot of it. Do a search for knuckle boot grease, you will come up with all sorts of threads.
I see you are new, welcome to the site. be sure to introduce yourself in the "new member requirements" forum.
Desperado08
Vallecitos/NM
Alright thanks and yes im new and a new owner to an m35a2 so I have alot to learn. Do you have any advice on where I can get service manuals for the truck also? I would like to do an oil change and fuel filter service on the truck and would like to know the priming procedures for the oil and fuel.
yamabro
Vanleer, Tn.
I would use a really high temp, good quality bearing and axle grease. Just get a 5 gallon bucket you'll need it for all the other points too. But check the TM to be safe
m16ty
211
Dickson,TN
There are some that say you don't need grease in there. We've had this discussion before and I tend to disagree. I'm not for sure which one is right but the TM says put grease in and I also worry about the thrust washer not getting lube.
I use NAPA wheel bearing and chassis grease.
DieselBob
13
Arnold Maryland
I also packed mine full of GAA when I repacked the bearing changed the knuckle bushings and replaced the wheel cylinders. I figure if nothing else it will provide at least a little protection from dirt and water if one of the boots tear and I don't notice it right away. 2cents
Zepol95
El Paso, Texas
I just did my boots..I was afraid of adding too much...I just did a tube in each one...but I have a feeling you can pack more in there...I am just afraid of OVER packing it...which was the case when I got this truck..
m16ty
211
Dickson,TN
Sometimes (ok, most of the time) I do notice it right away but will let it go for a little while because I don't feel like tearing into it. :oops:
I be careful not to go into any deep mud or water until I get it fixed though.
Floridianson
2,491
Interlachen Fl.
Diesel bob. if nothing else it will provide at least a little protection from dirt and water i 2cents[/QUOTE said:
I believe that by not putting any in there if you go swimming and you don't want to open it up and check for water right away you can do this. You just take out one of the 4 bottom bolts that that hold the end caps on the bottom and most of the water will drain out.
I have never cleaned out and repainted one to be pretty but I spray WD 40 all over and I'm done.
I put a good amount of grease in the spindel on reinstalling and in wipe off exess when the axle pops out.
FormerNewMVGuy
9
stockton NJ
Just wanted to add, That when i did my 5 ton front axle, it has the ball type axle, i put a new knuckle boot on ,slid the axle in an then packed it full of GAA before i put the spindle back on, But i have GAA in 5 gallon pails, so i just grab handfuls and push it into the axle and fill the knuckle, but you can only do it that way before the spindle is installed.
