barnyardengineering
- 0
- 0
- wilmington, ohio
Hi new to the site I recently purchased a 1970 m35a2 with a Hercules multi fuel motor. I noticed a small amount of smoke from around the turbo and seen that the back side of the heater injector was leaking where the snap ring apparently holds the end cap in is this common is it a simple take off replace o ring or should I try to find a replacement injector . Also if I take apart will I have to bleed the fuel system?
