M35A2 Lights
klq9386
arkansas
As I drive down the road the lights (interior and exterior) and turn off. After about 30 second (sometimes less) they come back on. I didn't know where to check from a ground / wiring perspective. Any help would be greatly appreciated.
NDT
7,365
Camp Wood/LC, TX
Circuit breaker inside the 3 lever light switch is cycling. It could be a momentary short to ground somewhere, too much load, or a weak circuit breaker.
Warthog
244
OKC, OK
And that breaker can not be manually reset. It is auto resetting
klq9386
arkansas
I dont know if it helps, but when it is acting up turning the switches off and back on it stays off. I dont follow where the circuit breaker is? Mind helping explain where I need to check?
Warthog
244
OKC, OK
It is inside the 3 lever switch. As far as I know it can not be replaced.
Bill W
47
Brooks,Ga
Mine would do the same thing when I ran with the high beams on, weak thermal breaker ( as already mentioned )
was my problem changed out the 3 lever and all is fine
