M35A2 no throttle
Kaleb7
Duncan, OK
I have a 1971 M35A2 with the Whites LTD 465. I just changed the hydraulic head orings and adjusted my fuel 1 flat on the bolt. Now once I got it started back up I have zero throttle. It will start and run just don’t have any throttle at all.
USAFSS-ColdWarrior
Chaplain
5,773
Did you make sure all the linkage inside the HH mated up correctly when reassembling? If something got out of alignment during assembly, you will lose control of the throttle. At least it didn't go to wide open when you cranked it up.
Just for CLARITY.....
A WIDE OPEN condition could result in CATASTOPHIC FAILURE through a runaway condition typically resulting in an EXPLODING ENGINE BLOCK as a result of a THROWN PISTON/PISTON ROD ASSEMBLY through the side of the BLOCK.
PLEASE read the associated threads on HH Rebuilds and how to be prepared to safely SHUT DOWN a runaway (wide-open throttled) engine!!!!!
