Machineman
- 0
- 0
- Serena IL
Hi,
I am having a problem with the right front turn directional not working. The other three corners are working fine. I tried swapping bulbs, checked connections etc. The marker light works fine on the light assembly so grounding there should not be an issue. I checked the voltage and found that it is low in that directional socket (6-8 volts), others are fine . What would be the cause for one socket to have lower voltage? Any help would be great.
Greg/Machineman
Greg/Machineman
