M35A2 speed boost
GUNGIY
OHIO
I was wondering what the best way to get little more speed, little less RPMs on a Duse and a half is any suggestions? :|
GUNGIY
OHIO
I was thinking mabby put a hire ratio the hi part of the hi/low differential
Eny thoughts?
BKubu
1,127
Gaithersburg, MD
Changing from 900 X 20s to 1100s will allow you to run at 57 MPH at the same RPM you would be turning at 50 MPH with the 900s (this has not been mathematically derived...figured it out from a chase car clocking me).
JasonS
139
Eastern SD
Somebody here on SS claimed to have drawings from rockwell for a higher speed gear set but he never got back to me.
grounded
Banned
928
defiance oh
Ouverson Engineering is working on making a set of 4.?? gears. but they are going to be pricey for this hobby i bet. its mostly for them rock crawler guys
quarkz
Supreme Galactic Cleric
71
Kennewick, WA
Sounds good.
But, don't the rock crawler guys want the ratio to go the other way, toward 7.17, like my school bus?
4.?? would be for the speed freaks, even if they were a bit pricey.
The bus has a Rockwell axle.
I was always looking for a 4.56 set for the bus so I could get over 60mph.
I rode the 7.17s all the way from Virginia to Washington state when I moved out west.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
Are you talking ring and pinion? Thats just dumb. Why replace 3 sets when you can get 1 gear from Tom? His kit also addresses the weak second gear issue in the trans.
