M35a2 speedometer runs backward ??
gimpyrobb
dumpsterlandingfromorbit!
27,791
787
Cincy Ohio
Its probably listed in the TM somewhere. I'll try to look under my deuce tomorrow and see if I can get any numbers for ya off mine.
Valence
565
Davis County, UT
I had that problem trying to get a 1:200 ratio speedomer adapter. See this thread for pics of the stock adapter and my "wrong adapter". The Wrong Adapter was actually a tachometer.
Start of the thread:
http://www.steelsoldiers.com/showthread.php?36012-Speedometer-Adapter-Leaking-Gear-Oil
Pics of the correct (stock) 1:187 ratio adapter:
http://www.steelsoldiers.com/showth...ing-Gear-Oil&p=1559207&viewfull=1#post1559207
http://www.steelsoldiers.com/showth...ing-Gear-Oil&p=1559826&viewfull=1#post1559826
http://www.steelsoldiers.com/showth...ing-Gear-Oil&p=1563867&viewfull=1#post1563867
Pics of the stock speedometer adapter next to the tachometer - which at the time I thought was a 1:200 ratio speedometer adapter, but no, it's actually a tachometer and the tachometer drove my speedometer backwards. The needle didn't go below zero, but the mileage rolled backwards.
http://www.steelsoldiers.com/showth...ing-Gear-Oil&p=1780386&viewfull=1#post1780386
MSenart
Kuwait City, Kuwait
Hopefully someone is not still having a problem with this one but if any one else has the the same issue check the assembly to ensure that it is properly assembled. I had this same issue in the early 80's and after trying 2 more new adapters from PLL which had the same issue I took one apart and reversed the lube fitting end and the cable connector end and it worked correct. And these were new out of the box assembled with the fitting reversed.
