M35a2--spun bearing? Rebuild kit or brushes for starter?
a2mrfreeze
colorado springs
i have a 1967 deuce with a multi-fuel engine, may have spun a bearing and needs a starter or brushes/kit. Can I just replace the bearing from the bottom without pulling the motor? where can i get one? The motor was run out of oil till it siezed. I fixed the oil leak, filled it with engine oil honey and made the 200 mile trip home. It does not sound so bad, but definitely sounds different than it used to. I'm pretty sure when i drop the pan i'll find a spun bearing on the crankshaft
