M35A2 Transmission rebuild/replacement?
rmgill
14
Decatur, Ga
So I have lost 2 teeth on my 5th gear of my transmission. I need to probably swap it out as the truck is sitting at a friend's place in Northern Virginia and I'm in Georgia. It'll be hard to drive back and forth to do the work then order parts and then do that again.
Anyone know of a resonable source for transmissions and where I should try?
From this area, I guess my options are:
Eastern Surplus in Philly
Colemans and Saturn near Harrisburg, PA
Clark trucks over in WV.
jwaller
19
Columbia, SC
I have a good one I was going to install in my deuce so I can return the loaner but if you need it I could sell it to you.
BKubu
1,148
Gaithersburg, MD
Call John Winslow in Halifax, NC (252-883-2509). He's got transmissions and he is right off of I95 near the VA/NC border.
m-35tom
221
eldersburg maryland
if you want to fix yours, i have all the parts and they are cheap, also i am very close. if you brought the trans to me, a rebuild only takes a few hours..............
rmgill
14
Decatur, Ga
Thanks Tom, I'm probably going to be constrained for time and, frankly, I don't mind the idea of having a second transmission laying around as a spare once I get the good one swapped in and then take the time to rebuild the dodgy one.
1,808
Hey Tom, I have a tranny out back that the counter gear to 5th is missing teeth. Have anything like that I can use?
wreckerman893
Possum Connoisseur
15,628
2,046
I will be pulling a tranny this weekend out of a donor truck.
I am in NE AL so you are not too far away for pickup.
200 bucks gets you the tranny and you can see if there is anything else you need.
I have a buttload of deuce parts to include two engines, TF case, axles, ETC.
PM me for details and phone number.
DDoyle
80
West Tennessee
depending on how north in VA the truck is - you may try M35Tom - his is in the Baltimore area, and I think he mentioned having some transmissions - or parts.
Regards,
David
TiredIron
Parker, Colorado
I have a Buddy that needs a good complete tranny out in Colorado just north of Denver. Does anyone know of any close option out there...??? 303-912-2170
TiredIron
rayraybigmfr
New Jersey
I have a trans, I dont know if it is any good, I came as a spare to an m35 I baught, who ever has the best offer, its yours, I dont know what they are worth im in south new jersey
