M35A2 Transmission Swap ?
Smokindieseldually
Kelowna,Bc
looking for some advice. 1971 m35a2 , started getting a knocking in 5th…. Have not had time to pull the cover off and inspect yet. I’m located in Canada so parts have been somewhat difficult to find ! Question being I did locate a spicer 6353 and a spicer 6352 locally… with a bell housing swap would either of these transmissions be compatible in my deuce ?? Thanks in advance!
gringeltaube
Staff Member
2,522
Montevideo/Uruguay
.... with a bell housing swap would either of these transmissions be compatible in my deuce ??
No, not compatible at all...
There simply is not enough room for a 6352, it's almost twice the size (and weight) of the 3053. It also has a larger input shaft and output propeller flange.
Most likely you will find your 5th gear with one- or more broken teeth.
Hummer Guy
807
United States Louisiana
I was about to say the same, and is there any transmission that's close to the same size as the 3053 that would have a better overdrive? I was thinking of the Eaton 11605A but they're hard to find and I'm not even sure what's the size of it
simp5782
Feo, Fuerte y Formal
9,369
Mason, TN
Spicer bellhousings and input shafts are ALL interchangeable with each other. Least some engineer had a brain.
