Hummer Guy
- 807
- 93
- United States Louisiana
I know this been talked about a lot, but I haven't seen that many actual swaps with the m35a2 trans other than the Alison AT545 and the same Spicer. Has anyone swapped any other transmission in the m35a2 with a longer overdrive? I was thinking about the NV4500 since its close to the same size of the 3053a, but it will need some modifications to handle the weight of the M35a2 since its only designed for 14,500 GWR. What other transmissions is there to fit? Preferably a manual but I'm open to hear what autos would fit as well. Also, if you swapped something different, what did you swap and what modifications did you have to do?
The main reason I'm looking into this is because I have 2 leaks coming from my spicer and I'm tired of the 1st to 2nd shift.
