M35a2 Turbo Temperature to shut off?
Hummer Guy
800
United States Louisiana
I notice on the C Turbos that you suppose to let them idle for 5 minutes before you shut them off, one thing I always wondered. What should the temperature of the turbo be before you shut it off? I currently have a temperature gauge to monitor the temperature and boost of my turbo
simp5782
Feo, Fuerte y Formal
9,329
Mason, TN
I don't shut any diesel down until the exhaust gas is at its idle temperature. 260 to 300 degrees. This will vary by engine though.
rustystud
2,760
Woodinville, Washington
I let my mulifuels run 15 minutes after a long haul.
And run ten minutes after startup to drive.
When I was still in the Marines we would allow the engines to run for almost half an hour before going out on a convoy. During that time we would do our pre-trip inspection . Checking over the truck for any leaks and tire pressure and such. Of course we checked the oil level before starting the engine !
Floridianson
2,491
Interlachen Fl.
Myself 260 / 270* EGT on the Duramax and 5 minutes without a pyro on the MV's. For the Duramax it is about 2 minutes to get there but the turbo is also water cooled. With 260 /270* EGT I believe the metal in the turbo shaft has cooled down enough to shut down.
