M35A2 voltage problem
dschuler
Chantilly, VA
Hi, I'm having issues with my '68 Deuce. When I check the voltage out of the batteries, I get 24v but I know I should be getting 26+volts when the engine is running. It has what looks like the 25v generator with the external regulator. My question is... could it be a bad ground?? because it does it randomly. I'm mechanically inclined but new to the 24v world. Any suggestions are very much appreciated.
Jeepsinker
397
Dry Creek, Louisiana
You should be getting 28-29v with the engine running. You need to do away with the old generator/ external regulator and replace it with either a civilian upgrade or the military 28v alternator. Too many failure points and modes of failure with that old setup.
