M35A2 - What are the mechanical weakest links?
bsteinborn
Keller, TX
My M35A2 is a recent purchase. Tried driving the truck from CA to TX but the clutch plate went out in AZ. Replaced the clutch plate once it arrived in TX. Later one of the radiator hoses blew, I didn't know how old the radiator rubber hoses are so I replaced them all. Got to thinking I didn't know how old any of the parts are. So I have replaced the wiring harnesses, the rubber brake hoses, converted the air wipers to electric. The engine and transmission run well, no leaks. So I guess I should wait until something breaks but was just wondering if any single component or components causes more trouble than others. Thanks!
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
The parts could be OE to the truck. You are correct, wait till something breaks! Might want to check the bearings and brakes, it is a single circuit system and if anything goes wrong with the brakes, it could leave you with no brakes.
