- 461
- 78
- 28
- Beaumont in SoCal
Hi All:
Recently my engine has developed a random problem.
It can be idling normally at normal temp and then drop RPMs and start chugging and puffing grey smoke. Revving the engine will not make it go away. After a bit it resolves itself.
I have dropped and cleaned out the tank. replaced the primary filter twice (not bad the second time) and the secondaries have less than 150 miles on them. I am burning straight, fresh diesel #2 and I add a small amount of fuel lubricant when I gas up.
I did spend some time searching but did not find this problem previously mentioned.
Home fix or send the pump out for rebuild? Or possibly a defective injector?
Thanks for any pointers/advice.
-Ken
-Ken
