M35A2 Winch DriveShaft U-Bolts. Help!
dropaduece
harpers ferry, wv
Dear Fellow Members,
I have my winch pto mounted up and now it is time to run my winch drive shaft up to the winch.
I have one problem though. There is two U-bolts that hold the winch drive shaft to the winch's yoke/ u-joint.
My U-bolts threads are damged and cannot be used, even with trying to clean the threads up.
My question is where can I find a new set. Are these u-bolts common parts that can be found or are they special order items.
Worst comes to worst I am sure I can get them from tnj murray yet would like to get this done this week.
These u-bolts are slightly flat to accomodate the yoke.
Any advice would greatly be appreciated.
Seth
1,177
Look for a Fleet Pride near you.
1,177
Rupert WV
25984
Rupert Truck Center304.392.2030
They are driveline specialist. They will have them or get them for you. Take your old ones with you.
gringeltaube
Staff Member
2,518
Montevideo/Uruguay
U-bolts
FYI, the very same U-bolts can be found in older Jeeps and most 1/2ton 4x4s with Dana/Spicer axles.
G.
1,808
As G said, they take the same Spicer 5-153X joint as most older half tonners and Jeeps. Very common item.
