I'm slowly working my way through all the problems on this truck we recently bought and now I'm at the wipers. With 40 pounds of air registering, the drivers side wiper works fine however the passenger side will track to the right and not return. You can tell that it's getting air because it's under tension and hard to manually pull back. Also the red button on that one is stuck in and will not pull out. I read a couple of other posts on this but they didn't suggest what might be causing this and if it's repairable. If someone more familiar with this problem could please offer some further advice on how to repair (if possible) this motor I would be very grateful. Thanks Lenny
