M35A2 wiring harness in a M54A2 multifuel?
amick
NW Montana
I am still having trouble getting my left turn signals to work with the headlights on. While going over the wiring I noticed the wiring was in very poor condition and was looking to replace the entire harness. I have a 1968 multifuel M54A2 5 ton. Will a M35A2 multifuel harness work?
vtdeucedriver
Vermont
You would certinly have all the right Set up when it comes to under the dash. Where the problem will be is from the cab out to all your lights. The wire would be a bit longer for the 5 ton. Call around, I bet you will find that the 5 ton harness is cheaper anyways.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
The starters are on opposite sides of the motor between the deuce and 5ton. Might be a "gotcha", might not.
