m35a2c wire diagram
1,806
Yes Sir! TM 9-2320-361-20. Go to appendix E and there will be a foldout there of the schematic. Have fun!
mangus580
282
Western NY
Randy, the TM in the TM section does have the foldout! was using it the other day, and it might be easier to read than the one bjorn has here.
Boatcarpenter
17
Marlborough, NH
At some point in time I think I remember seeing a listing of all the wire #'s for a Deuce in numerical order. Am I dreaming or is there such a list and if so, where do I find it.
Thanks,
BC
cranetruck
75
Meadows of Dan, Virginia
Since I have been messing with the fuel pump circuits latelty, I couldn't but notice the #654 wire is not listed.
It's the feed to the fuel pump as can be seen in the diagram posted above.
Boatcarpenter
17
Marlborough, NH
Mystery Light
Is the second dash warning light from the left in this pic the low air warning light if properly wired? Mine is wired but has the solid brass cap on it. If not low air, what the heck is it. Very difficult to read, but I think the # on it is 07.
1,806
The number on it is 27. Those are the lights that light the gauges. They emit light from the back through a little window on the gauge behind the dash panel. When equipped, the standard location for the low air warning light is right in the center of the dash and it has no brass cover at all, just red lense.
