M35A3 alternator conversion
shannondeese
High Springs Fl
When I bought my A3 the generator was frozen up. I had the local electrical shop put together a 22si delco 24 volt alternator for me. It’s a one wire hook up. Has anyone else done this on the A3? I did it on my A2 but the wiring was different. If you have can you tell me how you wired it? Thanks.
simp5782
Feo, Fuerte y Formal
9,339
Mason, TN
If it's a brushless unit just one wire to the 24+ on the battery or at the starter if it's closer and a ground wire for the alternator if needed
Eliteweapons
Baltimore Maryland
Good Morning,
The wiring diagram is in tm9-2320-24-1-2 on page 750. Looks like wire #2 and 770n needs to be connected to the alternator output. Wire 770p needs to get connected to the ground wire already there. Cap wire 568. I have not done a 1 wire conversion on mine but this looks like what needs to be done. Maybe someone else has actually done it and can help.
I hope this helps.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
I put a modern 1 wire 24v alt in my M725. Just run the large wire to the + output and cap the small one.
glcaines
2,544
Hiawassee, Georgia
A good alternator shop should have been able to repair your old alternator. Probably just a bad bearing.
