M35A3 CTIS COMBAT RIMS
cruzinz28
Maryland
I have aquired 4 M35A3 Rims for my bobbed deuce project so I can run my 14R 20 Michelin XL tires. I have two questions about these rims.
Do you have to have the counter balance weight under the rims studs and nuts to balance out the CTIS setup on the other side of the rim? I am missing one and trying to obtain it from the gentlemen I purchased the rims from.
Is there a way to eliminate the CTIS setup on the face of the rim and convert them to a typical valve stem setup?
I'm sure I will have many more questions as my project begins this weekend to bob my deuce. Oh, and if anyone is intrested I have a set of 7 M44 "SUPER SINGLE" rims I want to get rid of since I found these A3 rims.
EdMontana
TN
Just take all the CTIS system out and plumb the inflating tube for a valve stem. You will ended up with the CTIS valve and plumbing, CTIS cover, counter balance weight and two nuts left out.
The M35A3's spare tires come with just the valve stem set up .
