M35A3 CTIS Manifold PSI
kubotaman
124
RI/MI
Other than leaky O-rings we have had no problems with the CTIS on our M35A3. Went to start it and use the CTIS this morning and the control panel shows "Manifold PSI 00" before changing to a flashing "FLAT". I manually filled all the tires but still the same read out. Anyone else had this problem? Not interested in removing the CTIS.
SniperCow
Parrish FL
hello
did you find a remedy, or cause? any info would be greatly appreciated.
moocow
HDN
4,924
Finger Lakes Region, NY
Maybe there's too much moisture in the system and it's freezing the air pressure sensor in the manifold? Maybe the air dryer needs to be serviced. Just a guess - I've never had mine apart as I've removed all the CTIS wheel valves from my truck and the system ECU never worked for me.
