M35A3 ctis questions
hukfin
Palmer alaska
I am feeling kind of silly at this point as I have searched every combination of words with no luck. How do I remove a tire/rim with ctis from a M35A3? Not the tire from the rim. How does the CTIS disconnect for tire repair. I'm sure there is a post or video somewhere but I'm not finding it. Thank you for your help.
Scar59
41
Mt. Eden, KY
First, take the stone guard off, two bolts on the axle cap and two nuts on the tie bolts. Disconnet the air line , push the white collar at the connectors inward and pull the air line out. Loosen the 6 lug nuts. ( left side of truck are reverse thread,
clockwise to loosen.) Wheel assemble is very heavy. Report back
Karl kostman
893
Fargo ND
Another possible option here hukfin is to get a set of TMs for your truck and give them a read! You would be amazed at the level of knowledge that can be found within!
KK
