M35a3 lights flicker
Msf North Carolina
North Carolina
I have led lights in my M35A3 1992 like this when I bought it. The headlight cut off when truck ideals down and come back on when it ideals back up also when driving ... any help would be appreciated thanks
ncfirefighter140
FiremanPhil
19
Central North Carolina
Is there a resistor wired in line to each headlight. If not you will need them in order to get and keep the proper voltage to the headlights. Also if there is one in line it could be going bad and also make sure they are secured in place and not just flopping around.
ncfirefighter Southeastern North Carolina
M35A2
5ton soon
sue
376
tulsa OK
LED lights are not the best for dimming,
What that means is that you need a
Minimum voltage to keep them “on”
I’m guessing that at low RPMs your
Alternator is allowing the voltage to
Drop down a little?
Ajax MD
1,435
Mayo, MD
What @sue said. LED's operate within a "range." At idle, you're dropping out of that range, below the minimum.
Your generator may be able to be adjusted to keep the minimum within the range.
I'm pretty sure the generator(?) voltage regulator is adjustable but I haven't done detailed research into this because I haven't had any problems yet.
davidb56
1,238
Bonners Ferry Idaho
If your alternator /regulator is working correctly, you should have close to 28vdc at idle. Check that and eliminate a low voltage source problem. Then work your way up to the lights checking the voltage at idle. Ive seen faulty regulators cause idle voltage problems, low idle rpms, and even a undersized alternator pulley cause low voltage at idle.
Msf North Carolina
North Carolina
M35A2
5ton soon
No resister, I'll go get one and try that ... thanks
davidb56
1,238
Bonners Ferry Idaho
when mine takes a dump. I'll find a late model aftermarket alternator/regulator, even though it may not be "submerge proof", it will be cost effective to replace when it goes out.
davidb56
1,238
Bonners Ferry Idaho
I have a A2. I just noticed you have a A3. I haven't had to change mine, so I haven't researched it too much, but I figure I can modify something to fit, not OEM for around 250$. yours is about 5-600$ for OEM type, so I would personally go the regulator route first. I read somewhere that when the alternator itself starts to go, often you will get high voltage ( 30+). If thats the case, then you'll end up replacing the whole unit. research replacing it with a aftermarket (not chinese) prestolite or delco unit before you buy anything.
HDN
5,467
Finger Lakes Region, NY
I'm not too familiar with M-series LED replacement lamps. Would they really need a resistor? I'd think that a resistor would be built-in to the lamp as being one less part to screw around with.
It's one thing when working on a vehicle with CANBus, but for something as simple as an A3? I'm surprised a resistor is even needed. Unless I'm missing a detail about the OP's LED lamps...
ncfirefighter140
FiremanPhil
19
Some come with them built in some don't. Mine in my F250 did but I have seen some that didn't for military truck use. You can tell if there is one because there will be a in line box or one wired in line. Either way you would know and see it if it was there.
M35A2
5ton soon
