M35A3 Not Shifting into High Gear!!!!
AceHigh
30
Princeton WV Lake City FL
Did you check the fluid level under the floor on the passenger side? Did it shift OK when you got it and now does not? Have you changed out the filter and fluid? Often it is a badly adjusted shift cable in the shift tower. (Speaking as a person without much knowledge on this)
