Warren Lovell
- 4
- 18
- SAN DIEGO, CA
Hi Alpha 3 guys, I just wanted you to be aware of a potential problem with the power steering lines. As I was inspecting my truck before a drive I noticed the inside of the driverside front tire had a rub mark. Although nothing touches the tire when you drive straight, when you make a right turn, the inside of the tire might contact the power steering lines. It doesn't look like it can be re routed very easily, and the factory put a rub cover on the line. Just be aware you might want to check your lines for wear periodically.
That is all!
That is all!
