M35a3 rear diff center sections NG
HFDm715
Monroe twp NJ
My Fire dept has an M35a3 we received from Forest Fire service, It has served us well for the last 6 years with Water rescue and Brush Fires, I have Pm'd it every year, changed all the fluids, and flushed the rears when they were contaminated with water , getting ready for Fire season this year, and found both rear center sections have bad bearings on on the shafts the yokes are attached to, started to pull it apart tonight and also found the intermediate shaft that also has bad bearings, is this common? the front diff is good, but am going to have to rebuild both rear center sections. am wondering due to that fact it doesnt have a power divider and they are always engaged if thats the nature of the beast.
Duane
gringeltaube
Staff Member
2,426
Montevideo/Uruguay
I haven't had the bearings go bad, but I've had the pre-load go away and the pinion start to wonder!
Same here. Had to re-adjust preload there, more than once, while the bearing still looked OK.
I think this happens more often when the cup fits too loose in its bore, allowing it to rotate and slowly "eating" its way into the retainer.
Re-installing the same cup with some Loctite 620 would probably help, but not sure for how long, given the relatively high temps...?
G.
Jeepsinker
410
Dry Creek, Louisiana
High temps? After a long drive (~200 miles) or so my diffs are right at 100*F , measured with an infrared temp gun on the top portion of the housing where the pinion bearing rides. My rear axle runs 100* on the front pinion and 158 on the rear, so I figured my rear bearing might be going bad.
gringeltaube
Staff Member
2,426
Montevideo/Uruguay
Well, yes: too hot to keep my hand on it for long - but that is after hours at red line (-> 2600 eng. rpm), in our summer time.
And I actually had the "rear" bearing in mind... That is the larger one, next to the pinion, which gets all the load.
G.
HFDm715
Monroe twp NJ
Not only is the idler shaft really loose, but after taking the inspection cover off the side, found the intermediate shaft has some play too. Just ordered to nos center sections from eastern surplus, we have to go there and pick up 2 new tires, I will rebuild or rebearing the ones we take out and keep them for spares. We have a 500 gallon skid tank on the back.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
G.
What about the red loctite? I don't know which model numbers are what, but I thought the red was good up to about 500*?
Jeepsinker
410
Nice when you don't have to pay for the parts isn't it?
