M35A3 Tires
ohfiredude
Chesterland, OH
Does anybody know the standard tire size for a M35A3 deuce?
Also, can anybody recommend a place to buy these tires where they aren't super expensive?
Thanks!
OFD
ToddJK
4,515
Sparta, MI
Considering what I've read on a few threads, the 395's are more available and cheaper than the stock A3 tires Simp listed above. From online sources, I noticed most 395's (Michelin) are typically around $120-$200 depending on condition and if they have a rim or not, run flat or no run flat, and lastly, from whom. That doesn't include shipping if they need to be shipped.
ohfiredude
Chesterland, OH
Thanks ToddJK! I've seen some Michelin 395 tires that look to be in really decent shape for around $250 - $400 each. OTOH, I've seen some of the same tires go for as much as $1,200ea. new!! o_O
ohfiredude
Chesterland, OH
A quick search showed me that new Michelin XZL 395s cost about $2000 each. New Continental 365/80R20 tires are $800-$900 each IIRC.
Be careful buying surplus tires. If a shop thinks there's too much sidewall cracking, they may not pass a vehicle safety inspection, historical tags or not.
HDN, thanks for the heads-up on buying surplus tires. I'd hate to spend money on tires only to realize they are unusable. Because new tires are so expensive, I'll either have to save up to buy new Continental tires at $8-900 each. Ouch!
Michelins at $2K ea??!? No way!! That would be $12K for a set of 6 and I wonder if that would include installation.
  • Like
Reactions: HDN
HDN
4,923
Finger Lakes Region, NY
At a minimum I suggest getting newer (younger) surplus tires to put on the steering axle. The rear ones aren't as likely to cause major control issues should one blow up.
