M35A3 to A2 brake transplant
1,807
Proportioning valve, brake pedal assy, master cylinder assy, extra air pack and mounting assy, dash light assy and wiring for said items. On a side note, once you change to the split master you will no longer have a place to mount your winnch PTO shifter if you have one!
1,128
So the '86-'88 Deuces with dual circuit brakes must be slightly different than the A3's?
