M35A3 window regulator
DownRange762
Zachary, LA
Just got my M35A3 yesterday and was wondering if anyone had a good exploded parts view of the window regulator/door assembly? The passenger side window is halfway down in the door and the regulator is partially dismounted by the prior owner and I'm not seeing how to remove it for repair, or how to get the glass&frame out of the door as the glass needs to be replaced as well.
The view even with the access panel is limited but I expect this is one of those once-you-see-it, it-is-simple things.
Any helpful advice would be helpful.
gringeltaube
Staff Member
2,472
Montevideo/Uruguay
DownRange762
Zachary, LA
Thanks Gringeltaube, the exploded view is what I needed.
Got the window and frame out as well as the regulator. The clips were in the bottom of the door, guess one had popped off prompting the prior owner to start the disassembly.
Anyone using anything other that white lithium grease after cleaning the regulator before reinstalling it?
