M35A3 Wiring questions
DIESEL PULLER
VIRGINIA,MINNESOTA
I had an isolated fire/meltdown and I am wondering if you can buy a wiring harness for the M35A3. Does anyone know what the shielded wire that runs from the cab down to the battery block is for? Also, what does the solar panel power up? There is a component about 3" x 4" by the battery that I think says solarized. Any information will be appreciated.
Randy
crazyplowboy
Champion, Ohio
The solar panel is most likely a Solargizer which uses sunlight to desulphate and keep the batteries charged. If you do a search of the site for solargizers you will find more infor mation. As for your other questions I can't help you out as I have no real knowledge of the A3
lonegunman
Eastern, Washington
