M36 Deuce rear driveshaft?
Dead pilot
135
Fallbrook, CA
So I'm looking at this M36 Deuce and it has a missing drive shaft and carrier bearing and I was wondering how hard are those parts to find. Otherwise the truck is pretty good shape. Motor needs to rebuilt and cab needs some work but with look over that is what really stands out.
Tracer
13,824
Hawthorne, NV.
Give White Owl Military trucks a try. PH# 252-522-4331 If it needs a motor, I hope your getting it at a good price.
Dead pilot
135
Fallbrook, CA
So no one seems to have a m36 driveshaft. One of them told me the m35 driveshaft would work. But that doesn't seem right cause I though the rear axles were further back then the m35s axles
Sent from my SM-G930V using Tapatalk
Dead pilot
135
Fallbrook, CA
That's one I need. Haha. It has the front driveshaft and the one from the 2nd axle to the 3rd axle but missing the transfer case to 2nd axle. And that seems to be to pain to find.
Kaiser67M715
26
NH
You may need to get one made up, get a regular m35 one and get it lengthened
Sent from my LGL34C using Tapatalk
rchalmers3
30
Irmo, South Carolina
Don't know if you have local driveshaft services available, but I used to use Driveline Services of San Diego located in the Morena area of San Diego for my drive shaft needs. Phone:(619) 275-0150
Rick
Dead pilot
135
Fallbrook, CA
I have a place I've used for another project Oceanside driveline but if they can't do it I'll this place thanks.
Kaiser67M715
26
NH
forgot to mention, but you probably already knew, but any well supplied driveshaft shop should be able to put in a carrier bearing and extra joint, as they extend an m35 one. So while not 100% stock, it would certainly get the job done,(m36 is 4 ft longer right?, pretty sure that would require a carrier bearing)
gringeltaube
Staff Member
2,426
Montevideo/Uruguay
I happen to have exactly what you need and since I don't have a M36...... Only problem is distance.:-(
Still, this shouldn't be too difficult to solve there, with a bit of luck and patience.
Here are a few facts:
1) The M36's wheelbase is exactly 36" longer than the M35's (190"vs. 154")
2) The M36's (TC-to-FWD-rear-axle) -driveshaft is a two-section driveshaft, supported via a center bearing asembly, aka pillow block.
3) The rear-section-DS is exactly the same as on every M35 in this world.
4) The front side of the front-section DS is identical to the rear end of the M35 DS. The rear side has no slip-joint but takes that pillow block and a companion flange (#13) which is the same part number as the ones on every Deuce differential (#7521276).
5) The distance between that companion flange(face) and the (#19) front yoke's face is... you guessed it: exactly 3 feet - which is no surprise, of course.
If I had to build me one such "intermediate" driveshaft I would cut a stock M35 DS to correct length and weld it to a splined shaft, possibly a rear output shaft out of a scrapped Rockwell T-case, modded. The companion flange & nut would be there, also. The rest of parts like bearing/bearing support, etc. should be easy to find in most every truck junkyard, and eventually adapt a bit (I think...)
Attached some pics...
gringeltaube
Staff Member
2,426
Montevideo/Uruguay
Yes it could... also, this could easily be imported into your country for a super-low tax, as "antique truck parts", which it is.
But... the only carrier we had to ship this would be DHL, and that may cost you several hundreds.
Let me find out how much and PM you back with results.
G.
