M36A2 wheel base
jasonjc
283
Gravette Ar.
Does anyone know the wheel base for the M36A2???
I just got a fixer-upper and I'm trireing to decied whow to get it home.My 22' trailer or towbar ???
Will it fit on trailer???
If I use the towbar will the small adtapters work if i put bushing in the tow eyes??? If not I need to find (buy/trade) a set of the bigger ones.
TIA for any info
(GL sale norman OK)
M1075
Oklahoma City
I wouldn't think it would go well on a 22' trailer.
Center of Front Axle to Center of Rear Axle=214"
Overall length wow=330"
Weight=15-16,000#
1,806
You can bush the shackle brackets and use the 3/4" pins. The same 3/4" pins are used to adjust the length of the towbar as well.
Desert Rat
You will need to flat tow it. When you do use the side roads and US highways and STAY OFF the interstates. I'm doing that with my trips. The truck will be better off too. Plus it's much safer at slower speeds if something goes wrong.
