M37 4BT Engine Mount
MIKE2A6X2
SOUTHWICK, MA
Ive come across alot of people talking about the m37 4bt swap so is there anyone here that has made or can make another set of motor mounts? I would try a machine shop but explaining to them exactly what i need would be harder than asking some of you experienced fabricators that have already done it.
-Mike
Tanner
11
Raleigh, NC
Mount design & location will depend on the transmission combo you use behind the 4BT -
Cabell Garbee here in Raleigh, NC has some info/pictures on his website...
Engine Mounts
Note also that M-Series Rebuild/Charles Talbert's 4BT installations often use the Spicer 3053A Deuce transmission behind them.
'Tanner'
Tanner
11
Raleigh, NC
All Cummins 4BT into M37 swaps will be custom... deciding factors will be what bell housing & trans you use, power-assisted steering or no pwr assist, are you building a truck w/ winch or without, etc...
No one I know of makes a bolt-in set of mounts due to the numerous variables on installing the 4BT...
'Tanner'
