M37 doors
JT Wood
Calgary Alberta
Hey guys.
I'm currently on the lookout for my first MV. I'm leaning m37 or m135/m35.
I found an m37 close by that is a runner. Amazingly it has almost no rust. It looks to be in pretty good sharp body wise. The questions I have are
1. The roof is damaged. Apparently the shop where it was kept collapsed and damaged the roof and the hood slightly. The result is the window on the drivers door window seems to be wiggly. I don't know if the 2 are related. But I can really pull the window away from the roof 1" when the for is closed. Can these doors be rebuilt?
Is it worth 4k?
Sent from my SM-N900W8 using Tapatalk
hndrsonj
Senior Chief/Moderator
362
Cheyenne, WY
Doors can be rebuilt, prices depend on where they are located. I personally would say rust is my biggest issue when looking at them.
Juskatla
-1
Vancouver Island B.C.
The window parts inside the door are available. Wiggly side windows can be wear and after 40yrs out of the military, most have not been maintained. There are lots of these trucks around in various states of disassembly out there. Doors are often in bad shape with the bottoms rusted out. Replacements from dry climates are your best bet if they can be found. US trucks are the same as CDN except for the engine, transmission and pto if a winch was fitted. Is it a Canadian model? Serial numbers should tell you if it is. For price, if its reasonably rust free in the bed floor and cowl vent areas, has the original 251 power plant and 24V ignition, you will be in the range. Non runner, major work, would be less because of the unknowns. For comparison, check the powerwagon site photo classified pages or the G741 M37 web site. Lots of members here are also on these web sites. Have fun....
