M37 experts
rizzo
Port Huron, MI
I am thinking of buying this truck. I have always wanted a M37
here is the info:
still all orignal as far as i can see.
flat head stright 6 runs good not a miss in it.
4 speed & reverce
4 wheel drive works.
good breaks, lights work,
PTO driven wench on the front.
drive it home
value????
Carter
Delta, Pa.
Looks like the orig. 24 volt generator and the fan belt have been replaced with non standard parts also it has civ. plugs and wires. Is it 12 volt? 2K sounds about right.
Capt.Marion
15
Atlanta, GA
Not a B1, as there are no bolts or bolt holes forward of the driver's door to indicate a door-mounted spare tire carrier, which was on EVERY B1. 2k sounds right to me. Go over there, take a look at it, drive it some, and go from there.
M-37Bruce
59
Midlothian, VA
Definitely not a B-1....the ff's have seen better days.
12 volt for sure, looks like a by-pass over the water pump & a hose to no where on the passenger fender well?
Carter
Delta, Pa.
Bruce, the hose to no where might belong to that heater? under the glove box.
rosco
Delta Junction, Alaska
The fuel pump has probably been swapped out too. It would take a lot to put it back, even close to original. Depends on what you want it for.
Lee in Alaska
M543A2
10
Warsaw, Indiana
Someone has done an awful lot of modifying as others have mentioned. The professionalism of these modifications will determine how dependable the truck will be, and how satisfied you will be with it. The left front headlight mount at the fender looks quite shaky. If you lose ground to these, you will burn out bulbs with regularity. Since the heater is disconnected, it can be assumed to have a bad core. As was said by others, it depends on what you are wanting the truck to be. If you want a more original truck, you might be better off to look for another one at a slightly higher price which would be more dependable and easier to get parts for. However, if you are good at mechanic work and have a limited budget, you might find it fits for you. Just have both eyes very open as you look at it, and ask a lot of questions. I would say the $1500 range is right.
Regards Marti
Capt.Marion
15
Atlanta, GA
Definitely start at $1500. If it's been rewired... lets just put it this way, I've completely taken the front end of my truck apart and put it back together, and I still haven't undone more than 1/2 of all the South-Carolina-Swamp-engineering that has been done to it in the past.
