M37 lift kit?
hndrsonj
Senior Chief/Moderator
363
Cheyenne, WY
Either have the springs re-arched, or modify a body lift. should be easy.
CGarbee
552
Raleigh, NC
Actually, as long as you weld the blocks to the axle, it is perfectly acceptable to put a block between the springs and the axles. Make sure that you use a new index bolt in the sping back that goes through the springs and the block in order that you properly locate the axle (the axle has a smal depression in the spring plate for the bolt head to fit into...). Blocks are used not only by folks who installed the older military Hercules DT3.7 repower kits, but also by folks using Detroit or Cummins power... Military installed blocks on the left side as part of the kit to install the spare tire on the side carrier (the "door mounted spare").
Want me to send him some photos of my axles...?
hndrsonj
363
Cheyenne, WY
Blocks are perfectly fine for the rear, but are not safe for the front even if welded!!
cranetruck
75
Meadows of Dan, Virginia
Appreciate the info! He is also asking about wheel spacers, which I guess could be machined fairly easily if not available off the shelf.
Keep in mind Adrian is 19 and wants to "play" with his truck, not restore it. :)
Thanks Cabell for the offer on the images, I'll let you know if he wants them.
CGarbee
552
Raleigh, NC
Bjorn, I'm thinking about going to a rally in WV this October (PW crowd is going trail riding...). If I do, I'll try to swing by your place on the way up...
m108
Tennessee
A 38in tire should fit with out a lift unless the front springs are very tired. A 12.50 38 will work on the stock wheels.M37's work very well on trails with stock springs & 36 or 38in tires. I have a 63 B1 and have watched others on several trail rides and they seem to go places other''modified"trucks do.Just my 2 cents worth!
