- 1,177
- 27
- 0
- Northern Minnesota
I got around to installing a late model NOS transmission in one of my M37s (The Woogie) today.
I picked up some rollover noise that I believe to be coming from the PTO. Given the Tannsmission is NOS I can't imagine it being in anything but the PTO. I've always been under the assumption that there is only one PTO and it fits both the old style and late model transmissions. Can anyone confirm this.
When the PTO was installed we could only use one gasket/shim and it "felt" right. Any more than one gasket/shim would have made the fit too loose.
I discovered when changing from old style to the new style transmission the winch "out-of-gear" safety catch in the floorboard tunnel has to be moved. Evidently the transmissions are different???
I also rewound my cable spool today. I don't ever recall unwinding the cable under power, (with the pto engaged and in reverse) so I don't know if the ticking noise at every revolution is normal. Always before I simply free-spooled the cable.
The noise went away when the PTO was in forward (winding in the cable) but there was a definate click and hesitation in the drum on every revolution when the drum was paying out under power.
If there are any winch gurus out there I'd appreciate your insight.
