Hey all, here are some photos of the inside of the shelter.. the outside is awaiting paint just like the truck, but the inside is done!
Empty Interior, just a big ol' box
Table setup in the front
Table set to the side
planks installed for the bed.
made up bed
Custom radio mount, this is custom designed to mount to the existing rails, so no extra holes. I put some narrow strut mounting for conduit, then attached the shelf to that so it can be adjusted.
The dimensions are designed around the radio mounting boxes, which are 22MM ammo boxes, with the lids removed. I mount radios in these, so the lids can be re-attached and they are very protected.
To attach the boxes to the shelf i use a long threaded rod pushed up through the bottom of the shelf, through the hinge holes, and bolted top and bottom.. they are very secure.
made up bed
