M373a2 Brake parts info
wrenchturner6238
29
Beaver Oklahoma
I am looking for some brake parts info for my M373a2. Where to locate a new master cylinder and wheel cylinders too. I have been searching through threads and use the search tool with no luck finding much. I have found a TM manual on the net but it does not give or have not found a parts manual.
wrenchturner6238
29
Beaver Oklahoma
Well I did find a TM and a parts book on line. the part number for the wheel cylinder is p/n is 8758259 NSN# is 2530-00-920-7568 I found these parts. I found a part number for the master cylinder is P/N 8332086 NSN # is 2530-00-278-2243. but have yet to find a cylinder any help with this would be appreciated
Floridianson
2,487
Interlachen Fl.
On my 373A2 it ran the same wheel cylinders as the 809 series 5 ton trucks and only has one slave cylinder per side. Two inch cups. Got mine from Memphis Eq.
I switched out the old axle out for a new S cam air axle 25k GVW and glad I did. If you can afford it that is a great up grade.
BigRig379
37
Ozark/Arkansas
I have the same master cylinder on my m129. Go to NAPA get a master cylinder rebuild kit #39. 1 1/2” cup is the size. It’s about $25
Sent from my iPad using Tapatalk
