M38 A 1
borky51
Hartland WI
I have a M - 38 A-1 when I get it up around 40 Miles per hour the front end starts to shemmy really bad everything seems tight, tires are good please advise Thanks Borky 51 The right phone Number is 414-708-1467
glcaines
2,494
Hiawassee, Georgia
Sometimes tires that look perfect can cause a shimmy. Try swapping the wheels from front to rear and see if you still have the shimmy. If the shimmy goes away, you know it was the tires or wheels.
exhogflyer
130
Albany NY
As has been mentioned try swapping wheels/tires or get them balanced ( spun not static). Also make sure alignment ( actually toe in) is correct. You want very slight toe in about 1/8"
