M38A1 Coolant Leak from Head/Block
lackndt
Mpls
Any advice on this one? I just put coolant into a 53 M38A1 that hasn't been run for years. There's coolant weeping out of the head to block joint at the right front of the engine. Is this a common problem? Do I need a new head gasket?
NDT
6,280
Camp Wood/LC, TX
Welcome to the site. Not it is not a common problem, and yes you either need to retorque your head bolts, or if that does not work, a head gasket, and to check flatness of both head and block while things are open. Don't forget there is one head bolt under the carb. If this is just going to be a hunting rig, you could try some of the auto parts store remedies before doing a pull down. Good luck.
jimk
45
Syracuse, New York
If you go that "auto parts remedies" look for Moroso Ceramic Seal. There are two types. One is for use with the existing coolant and the other is used with 100% water. The latter is the better product. I was never a big believer in miracle cures but tried it and it fixed a cracked head (1/2 gal per/day out the tailpipe) and a minor external head gasket leak at the same time. I got another 100,000 out of that engine with no coolant usage. I have heard the truck dealers have something good, called K/W sealer.
Bull Run
haymarket, va
Sounds like you "may" have a cracked block or blown head gasket.
Having recently had a similar problem I would pull the head and get a visual inspection of what is wrong to play it safe. May be minor or major but leaking coolant is obviously not good.
Pretty easy job to do and you will get a definitive answer. I hope that helps.
steelsoldiers
3,971
Charleston, WV
One other possibility is that the bolt near the leak goes through the water jacket and is leaking around the threads. You could remove, put some sealant on the threads, and re-torque. If it doesn't go through the jacket, then it sounds like a head gasket or a crack. Hope it is simple and cheap for you to fix!
1,127
Head gasket leaks on the F-134 are not uncommon. Plus it's 50 years old.
I'd check the head bolt torque and if it persists, pull it off. You can have the head off in 90 minutes.
wbrianiii
Riverside, California
If you haven't already done it, I would just go ahead and pull the head off. It's a real easy job, and the head gasket is fairly cheap. If you don't already have hardened exhaust valves, go ahead and install them just as a matter of maintainance while you're in there.
