M38A1 Oil Pump Removal
wesk
Wisconsin
You may have to unbolt the front mouts to help it clear the steering box. Remember this oil pump drives your distributor so you will have to address the correct indexing procedure to keep the distributor in time.
Balad03
How do you index oil pump to keep distributor in time. The gear at end of oil pump looks completley neutral.
